Previous in Forum: Do's and Dont's   Next in Forum: Toward an Epistemology of Duct Tape
Are Lean Six Sigma Tools usefull to project work industries??
07/07/2009 10:01 AM
Hi!!
I was preciousley with a company which was used to work on Mass production bases, there we had used some of Lean Six Sigma Tolls effectively.
But now I am in a company which functions on Job order function; which means there are very rare chances of repetation of same kind of job.
In this case, how we can reduce the lead time of each project using Lean Tools??
All the Lean Gurus please help!!!
Thanks
Good Answers: 243
Re: Are Lean Six Sigma Tools usefull to project work industries??
07/07/2009 12:17 PM
I will specifically deny that these techniques are "six sigma magick," but the first tool that I would do for your "project Job order function" is to create a spaghetti diagram and process flow chart of all the stops thatsuch a Job order project goes through, and also mark dwell times at each step. The following link will acquaint you with the idea, I am not trying to sell you their software. personally I prefer to draw in pencil to gain knowledge from the exercise. http://systems2win.com/solutions/z1.htm
Then I would determine for each step, whether or not value is added, and i would eliminate all such steps and transportation where no value addition takes place.
Ultimately, Eliminating non value added waste is what todays "lean" Yesterday's "industrial engineering" is/was all about.
Then at each step, I would create job aids, references and work instructions to standardize work STANDARDIZED_WORK and eliminate opportunities for errors. Standardizing the work and training to use the tools is how you will sustain your improvements.
Please read the following post about applying standardized work to software development.
http://www.infoq.com/news/2009/04/lean-standard-work
"Six sigma" is originally a statistical insight, which has been hijacked, misapplied, abused, and become smokescreen for much management malpractice. MAny of us on this board look at this term as a pejorative at best.
The techniques described above should give you a great start.
Final tip: When I ran an inside sales operation that had folders flying around between departments, and people with in thse departments, I had my team draw up the process flow chart for the process. We then printed these off and stapled them to the front of each folder, and they colored in the box as they completed it. It was a visual 'pokayoke' that showed at a glance what the state of work was (status) for each folder. This is what gives Lean its power. This alone cut down 60% of the time to get the orders routed through our system.
milo
07/07/2009 4:16 PM
Right on! GA, to ya.
I worked at Motorola military plants in the60', 70's and 80's in AZ when 6 Sigma was being implemented.
As an engineer in a materials lab, I hated it. We did plastic part prototyping, injection molding and hand casting and some PWB repair as well as coating PWB's for development.
I was forever tripping over some 6 Sigma mantra that only reduced our efficiency.
I can see it in a production environment, as Milo has described the process, but for me it was a wall.
