We have an electronic ballast that perfectly ignites and runs a 250w HPSV lamp.But when the same ballast is connected to a 250w MH lamp, the lamp flashes periodically but does not run. In other words, ignition takes place but the arc is not sustained. What could be the reason ? Both lamps work equally well when run with a conventional core and coil ballast and superimposed ignitor.
