Previous in Forum: Hydraulic Torque Converter   Next in Forum: Product design?
air condition
07/10/2009 7:39 PM
hello
i like to know about how can i choose my air condition depond on engineering rules depond on calculate heating load , BTU For all heating loads factors
thanks
eng., ahmed
Re: air condition
07/10/2009 7:44 PM
Residential, commercial or factory?
Re: air condition
07/11/2009 2:29 PM
Manual J, published by ACCA. Books by ASHRAE. It's tedious in any case.
Re: air condition
07/11/2009 10:55 PM
You want to translate that...!!!
Best, ...Lee.
Good Answers: 68
Re: air condition
07/12/2009 1:41 AM
Hello engahmed,
Here is some 'rule of thumbs' that may help.
][ How to determine the cooling capacity of air conditioning equipment 16 May 2007 ... Directory of Professionals to Inspect or Test a Building ... purchasing an air conditioner of the right size or capacity in Tons or BTUs. ... COOLING RULES OF THUMB - determining Cooling Capacity ... guide to selecting an air conditioning system with the proper cooling capacity in tons or in BTUs. ... www.inspect-ny.com/aircond/aircond03.htm -
Cached - Similar
Energy Savers: Sizing Heating and Cooling Systems 24 Feb 2009 ... Other methods include simple "rules of thumb" based on the size of your home or ... Manual J and Manual D: The Correct Way to Size a System ... The ACCA also offers a comprehensive guide for choosing home heating and ... To summarize, when designing your new heating and air conditioning system, ... www.energysavers.gov/your_home/.../mytopic=12340 -
Cached - Similar
Residential Buildings: Heating, Ventilating, and Air Conditioning 11 Jun 2008 ... Rules of thumb for equipment sizing do not work in modern homes ... contractor to properly design, size, and select HVAC equipment. ... Building America recommends integrating mechanical ventilation into the HVAC system. ... www1.eere.energy.gov/buildings/residential/hvac.html -
Cached - Similar
HVAC Sizing Rules of Thumb The acronym HVAC stands for Heating/ Ventilating/ Air Conditioning. ... In these systems, air moves between the inside and outside of a home or other building. ... Installing the correct size keeps costs down. Correct humidity control ... www.furnacecompare.com/hvac-sizing-rules-of-thumb.html -
Cached - Similar
Hope this helps.
Re: air condition
07/12/2009 2:31 AM
You have to carry out heat laod estimation based on the arch.drg and decide the capacity of the building if it is larger buildings. If it is smaller building many times thumb rule ( Tones of refrigeration per sq meter ) is used to select unitary type of air conditioners.
Re: air condition
07/13/2009 7:46 AM
Please refer the book of Refrigeration & Air conditionig by ANANT NARAYANAN. You will get all type of calculation.
Re: air condition
07/24/2009 9:36 AM
Thanks for all comments repaly me , i get specifications
My ask is about cross section for cable power for spilit cas HVAC home air condition for 2 HP , 3HP for long 70 meter . home unit.
i choose cross section 1.5mm or 2.5 mm for that long currant .
i see not need exceed about that .
like to read comments about my choosing .
Register to Reply 7 comments
Anonymous Poster (1); babybear (1); CMTec (1); engahmed (1); lyn (1); mrswamy (1); Nah (1)
