Previous in Forum: HP and RPM   Next in Forum: air condition
Hydraulic Torque Converter
07/10/2009 12:02 PM
Hello. I work in a lumber mill in Oregon and need some help with a machine design. We have a 80ft. drum debarker that we are installing. The drive is a 300hp 1180rpm motor to a torque converter coupling and then to a gearbox with a 9.406 ratio. We would like to use a VFD drive on the motor to get our motor output to about 700rpm. I worry that the torque converter will not lock up at that speed and wonder why we need it if we use the VFD to slowly ramp up the drive. Is the torque converter just for a "soft start" or is there another reason to use it in this application?
Thank you,
David Cassano
Good Answers: 101
Re: Hydraulic Torque Converter
07/10/2009 12:32 PM
I work in the Hydraulics Industry, and would not be suprised to learn that you are already one of our clients. We do a lot of work in the mills all throuout Oregon, and the Pacific Northwest. If you would like to chat, I'd be happy to help in any way I can. Send me a PM, or give me a call @ (503) 972-1515
I also work closely with the leading Guru in VFD's for all of Oregon.
In any case, We can help you.
My name is Russ.
Good Answers: 247
07/10/2009 11:30 PM
If it is a real torque converter, then it probably roughly doubles torque (when load is high) and reduces speed into the gearbox. It also will absorb shocks, and allow the debarker to jam briefly without damaging the drive. Unless it has a lock up clutch, it will not truly lock up, but will slip less as the speed gets up to its design speed. Under high loads short of jamming, the torque converter will increase output torque while allowing the motor to stay near its design speed.
Register to Reply 2 comments
