Previous in Forum: Harness   Next in Forum: Six Sigma Melds Data Collection and Analysis
Detecting Belt Slippage
12/06/2006 11:56 PM
I have a application where a motor is driving a belt. When the machine gets jamed the motor runs at the same speed and the belt starts slipping. I am trying to find a way to monitor the movement of the belt.
So far the only way I can think of is to put markers on the belt and count the pulses as it goes by but I was hoping there might be a better solution.
Thanks
Good Answers: 54
Re: Detecting Belt Slippage
12/07/2006 4:02 AM
Don't put a sensor on the belt, put it on the pulley. The pulley will have a shaft that you can put a sensing plate or bolt. If it has a set screw or key, you might be able to use that. If the belt slips the pulses will change in frequency or stop altogether if the belt breaks.
One other method we use in to utilize existing instruments. For example: we have a blower that supplies air to a dryer. The dryer has a pressure transmitter on the hot air inlet ducting. If the pressure dips, we know that the belt is slipping.
12/07/2006 11:00 PM
Hi, do you need the belt to slip, all v-belts slip, the amount of slip is determined by the condition of the pulleys and belt, also the tension on the belt. But even if the drive was set up perfectly, a wrapped v-belt will still slip about 5-7%.
If you do want slip then use a timing belt, then there will be no slip.
Big Kev.
Good Answers: 11
12/08/2006 12:04 AM
There are many commercial belt slip detectors available. Turck, Effector and Mann (now a division of Moeller) come to mind. Other means using your PLC (if you have one) are possible, but this is the easiest. All approaches listed utilise prox switches and targets on pulleys.
12/08/2006 9:29 AM
You can install a zero-speed switch on the driven pulley. There are a few different types, I have used ones from A-B and Electro-Sensors.
Good Answers: 247
12/08/2006 11:28 AM
You could certainly use prox switches on the driven and drive pulleys (counting pulses and comparing ratio). However, given reasonably good design, the motor will not ordinarily be running at its maximum torque. When something jams, torque will go up dramatically, given a reasonably tight belt in good condition. So if you sense torque, (via amperage draw) you can shut down the motor before belt damage or motor damage occurs.
Good Answers: 11
12/10/2006 7:14 PM
Ken,
Belt slip protection work for all sources of belt slip which is why we use them on conveyors. Once the belt slips the torque usually decreases particularly when the rubber starts to melt or burn. The electronic shear pin approach seems simple but ends up unreliable in practice.
Anonymous Poster (2); Blink (1); Emjay4119 (2); Vulcan (1)
