Previous in Forum: Bulk Density and Powder Particle Size   Next in Forum: Parts Cleaning
Indonesia - Member - New Member
API 5L Pipe - Grade A vs. Grade B
07/13/2009 6:40 AM
Dear forum
Does API 5L Gr. B and A 53 Gr b any difference?
I was seen that mechanical and chemical properties between both of pipe are equal
Yield strength=60000PSI; %C=0.3
My question is, May i use A 53 for kerosene pipeline?
Also posted in: also posted in Mechanical Engineering
Re: API 5L Pipe - Grade A vs. Grade B
07/14/2009 12:36 AM
Yes you can use ASTM A53 Grade B for Kerosene pipeline where there is no higher temperatures.
07/14/2009 1:46 AM
One diference between both ( Gr A and Gr B) is the Hydrotest pressure during the pipe fabrication progress. See notes for Calcs. of Hydro Pressure and the % of YS required for each one (API 5L).
Kerosene, Hummm, no problem. Watch out with temperature and isolation.
07/14/2009 1:53 AM
Good Answers: 150
07/14/2009 9:48 AM
API 5L Grade A 48KSI min UTS 30KSI min yeild .22% Carbon, .9% Mn.
API 5L Grade B 60KSI min UTS 35KSI min yeild .27% Carbon, 1.15% Mn
The chemistry and mech. properties are NOT equal. Grade B can be used in place of Grade A except where there might be an issue of H2S embrittlement.
API had a reason for making two different standards.
Who is John Galt?
07/14/2009 10:06 PM
I 'm sorry for missing title.
The correct title is, API 5L Gr. B vs A 53 Gr. B
Good Answers: 150
07/14/2009 10:59 PM
I'm sorry I missed that the first go-round. the ASTM standard is the equivalent of the API standard. The API standard came first. ASTM came along later and duplicated it as an ASTM standard.
Who is John Galt?
Register to Reply 6 comments
Abdel Halim Galala (1); Anonymous Poster (1); atorroja (1); AvatarIndo (1); Rorschach (2)
