Previous in Forum: Storage Control for Tubes   Next in Forum: sand production
WCB?
07/14/2009 10:22 AM
What is WCB?? (Regarding Materials..).
R.Arun
Friend of CR4
Re: WCB?
07/14/2009 10:31 AM
Weldable Cast B-Grade Carbon Steel ???
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Re: WCB?
07/14/2009 10:32 AM
Sir,
What is the speciality of the material??
Arun
Friend of CR4
Re: WCB?
07/14/2009 10:43 AM
Is that what you meant by WCB?
I have no knowledge of the material. I was just hoping to define the acronym provided. It was one of a number of things/concepts to which WCB could refer. Verify that Weldable Cast B-Grade Carbon Steel is indeed the material you are looking for, then someone with a materials background may be able to help.
Re: WCB?
07/14/2009 11:43 AM
It´s a denomination of ASTM for CAST AIRON
WCB stands for "Wrought Carbon" with Grade B.
there are 3 kind of Grade A,B & C which define the ductility & tensile strength.
Grade B is having very good ductility & tensile strength as compare to Grade A & C
if you need more information check the next page
www.matweb.com
or the ASTM web
regards
Register to Reply 4 comments
Anonymous Poster (1); Arun Ramarishnan (1); Chris Leonard (2)
