Previous in Forum: Protection against Lightning .......   Next in Forum: Inverters and Pole-Change Motors for Variable Speed Control
How to build pulsed current DC power supply?
07/14/2009 10:29 PM
I want to use this to find the contact resistance of the circuit breaker
Re: How to build pulsed current DC power supply?
07/14/2009 11:05 PM
Why do you want pulsed DC instead of continuous DC? What is the current rating of the circuit breaker (is it very low)? Even a small (relative) current will allow you to get a fairly accurate voltage measurement across the contact (as long as you employ correct 4-wire voltage measurement techniques).
Also, why are you doing this in the first place (is it for maintenance or measuring the contact resistance of a new circuit breaker)? The contact resistance data should be available from the supplier.
What's the application and what size circuit breaker are you talking about?
