Previous in Forum: airconditioning   Next in Forum: pump solution
control ststem
07/15/2009 1:46 AM
what is Damper?
Good Answers: 103
Re: control ststem
07/15/2009 2:11 AM
Friction (machanical), resistors (electrical)
But the header (control system) should not have been followed by this question
Homework ?
Study damped and undamped systems.
Re: control system
07/15/2009 2:15 AM
In a chimney it regulates the flow of hot gases upward. In an air conditioning system it regulates the flow of air through ductways.
It usually consists of a piece of sheet metal shaped to conform to the inside of the ductway or chimney and is adjusted to block, more or less, the air or gas flow.
j.
Re: control ststem
07/15/2009 3:50 AM
Dashpot dampers slow down the movement of a rod through use of a close-fitting piston and cylinder. The fluid friction between the two as the cylinder exhausts is used to slow the movement.
Good Answers: 266
Re: control ststem
07/15/2009 7:03 AM
Damper a noun can be an applied name to many devices. Look up the definition of the word.
Re: control ststem
07/30/2009 4:33 AM
Which system are you referring?
Anonymous Poster (1); Jack Jersawitz (1); ozzb (1); PWSlack (1); sb (1)
