Previous in Forum: Control valve   Next in Forum: Torque Rheometer
World wide Vendor of solenoide valve & switch
07/15/2009 2:33 AM
We had been requireded Intrensically safe 3-way Solenoide valve and push button switch.
So, please suggest world wide vendor for these two equiptment.
Re: World wide Vendor of solenoide valve & switch
07/15/2009 3:03 AM
Push button switches are classed as "simple apparatus" in Ex i circuits, and do not need certification for use in them, so any one would do.
South Africa - Member -
Good Answers: 12
07/15/2009 3:40 AM
Hi there,
You will still need to limit the energy put through the switches in the field. The solenoid is a different matter as it has the potential to store energy.
You could try Burkert - they have some good sloenoid valves: www.burkert.co.uk
Regards,
Craig
07/15/2009 4:10 AM
Is there a way of moving the solenoid itself out of the hazardous area?
  • Change the process valve to air actuation, and put the solenoid that switches the air inside the control panel?
  • Alter the location of the valve so that it is mounted outside the hazardous area?
Could an Ex d solenoid valve be used instead, thereby saving the need to fit an Ex i isolating barrier inside the panel?
