I come to you all for advice. I want to build what we call a flip flop box. It is designed to flip between 2 hid lights using only 1 ballast. It consist of dpdt relay, ballast, 2 lights, and a timer. People have been having problems with arcing between contacts destroying them. So what people started doing is powering down the ballast between the switching of the poles(i think thats right). I will be switching my lights every 2 hours and i dont want to shut down the ballast. Mines would controll a 1000w hid light. From what Ive researched the voltage coming out of the ballast is around 4-500v? I have been suggested to use a mov. but dont know how and where i would hook one up.
this is the most commonly used relay for this setup
that i know of.
NTE relay R04−11A30−120
this is the relay i planned on using.
Potter & Brumfield
T-92 series relays rated at 30A and are available in
various actions and coil voltages. Many manufacturers
are replacing large power relays with the space
saving T-92 relay. Dimensions are 2-3/4 in. x 1-1/2 in. x 1-3/8 in.
I really would like to use a 120v dpdt solid state contactor so i dont have to worry about contacts, but cant seem to find any that specifically say dpdt.
Any advice would be greatly appreciated!! Thank you
