Previous in Forum: 100A 3-Phase Cutler Hammer Pump - Breaker Model HMCP100R3C   Next in Forum: Converting a Natural Gas Space Heater
Rating of Pipe Fittings
07/16/2009 9:49 AM
What is the Class equivalent rating of pipe fittings in pounds?
What is the relationship btw class ratings and pounds ratings of pipe fittings?
Is pipe fiiting of , say class 1500, the same as a pipe fitting of 1500 lbs?
Good Answers: 101
Re: Rating of Pipe Fittings
07/16/2009 11:37 AM
As far as I know a 3000# fitting is rated to withstand 3000 PSI.
07/17/2009 2:25 AM
"As far as I know a 3000# fitting is rated to withstand 3000 PSI".
No.
I'd like you to know that there are a lot of people have the same thinking, therefore, please refer to CR4 Thread Pound Rating for flange rating, and CR4 Thread Piping Standards and Fittings for fitting rating .
07/17/2009 3:37 AM
That is incorrect and it is important not to make that inference. Please refer to the links in Abdel Halim Galala's posting above.
Good Answers: 101
07/17/2009 11:45 AM
Thank you for the correction... interesting, my fittings supplier uses this rating system... but they machine all their own fittings, so I suppose they can put whatever numbers they wish. In fact I've had a couple manufacturers use the "same number as the rating" system... So I suppose my new question would be "Why?" why wouldn't we make it simple... 150# = 150psi, 1500#=1500psi, 3000#= 3000psi??
At least thats how I order all my fittings, but Its a supplier choice I suppose. Sorry for the Incorrect info (at least I said "as far as I know").
(this is really something I should not have misunderstood, as I work in the Industry. More and More It seems like the Industrial Hydraulics Industry is so removed from the rest, as I always order either 1500#, 3000#, 6000#, or 10,000# fittings, which have the same pressure ratings... but again, this industry always amazes me... we still have no ANSI symbol standards)
And thank you again for the correction
Good Answers: 101
07/17/2009 6:26 PM
Well, I'm getting hungry. I guess I ought to wipe some egg off my face and make a nice big omelet. Yum.
Good Answers: 101
07/17/2009 6:41 PM
Register to Reply 6 comments
Abdel Halim Galala (1); PWSlack (1); RVZ717 (4)
You might be interested in: Pipe Fittings, Hose Fittings
