Our capacitor banks is consisted of 6 x 20kVAR / 6 x 30 kVAR and currently utilise around 6 to 7 capacitor banks out of the total 12.
The power factor meter is showing a range of 0.94 to 0.95 on the LAGGING side.
Our ACB is rated 1200 A and our plant is currently using only up to 525 A.
Our plant only uses small production machines. Only our air compressors and exhaust fans have 30 to 40 horsepower motors.
My questions to you all is as below:
(1) Is there any advantages of setting the system so that the PF meter will divert the reading from the LAGGING to the LEADING side ?
(2) What is the reason the MSB is commonly designed to the LAGGING side?
(3) What is required (material and equipment) to divert to the LEADING side ? Cost / Modification / Feasibility ?
