How to calculate and design the heatsink in the electronics power supply units like AC-DC converters, DC-DC converters. And give an example how to calculate the heatsink for 120 watt heat desipation.
Its not a word can be made clearly.
At first you would know the transistor's joint max tempereature Tt. and know the shell of the unit themo-resistance Rs
3] the heat sinker themo resistance Rh;
4]touch themo resistance Rt;
5]circumstances temperature Tc;
Then you can use formula
Pw=[Tt-Tc][Rh+Rc+Rs]
The result is the allowance power of the unit (transistor herein)
In the switch power, 120w is power beared by a middle low power transistor or mosfet t
If you need the power supply pls contact me at
info@ndt.cn
