Previous in Forum: BhargavThakkar : Car battery Repairing   Next in Forum: Battery Discharging
Usage of Spike Buster
07/17/2009 7:08 AM
Typically we use Spike busters for PC at home. It has three 3 pin sockets so that we can plug in monitor, system unit etc. Is it safe to use in office where we ahve UPS power. Does it lead to some problem.
Thanks for your views
Re: usage of Spike Buster
07/17/2009 7:27 AM
No problem - it's fine to use it with a UPS.
07/17/2009 7:27 AM
No problem. Go for it.
Good Answers: 140
Re: Usage of Spike Buster
07/17/2009 7:54 AM
Actually... most UPS manufacturers advise against plugging a surge suppressed power bar into the output of a UPS. Here is what APC, a large UPS manufacturer, has to say on the subject.
Click Here...
07/17/2009 8:11 AM
Ah! That's for 110V supplies.
Replies #1 and #2 relate to 230V supply experience.
07/17/2009 4:18 PM
I read the link and APC had this to say
Plugging a surge protector into your UPS: Surge protectors filter the power for surges and offer EMI/RFI filtering but do not efficiently distribute the power, meaning that some equipment may be deprived of the necessary amperage it requires to run properly ? causing your attached equipment (computer, monitor, etc) to shutdown or reboot. If you need to supply additional receptacles on the output of your UPS, we recommend using Power Distribution Units (PDU's). PDUs evenly distribute the amperage among the outlets, while the UPS will filter the power and provide surge protection. PDU?s use and distribute the available amperage more efficiently, allowing your equipment to receive the best available power to maintain operation.
Perhaps I am missing something here but virtually all standard surge protectors and multi-way strips fitted with surge protection provide said protection with MOV devices connected between phase and ground (or phase and neutral to ground) to divert spikes. They have absolutely nothing to do with distributing power on a multi-way board. This broad statement seems to be written by their marketing department and should be under the simple heading "if using a multi-way board take care not to plug too many devices into the output of the UPS otherwise you may overload it"
Good Answers: 140
07/17/2009 8:56 PM
Yes, I agree with you that the language is a tad ridiculous. "Distribute Power"? Hogwash...
There is more to this... gonna do some research.
Register to Reply 6 comments
jack of all trades (1); JohnDG (1); North of 60 (2); PWSlack (2)
You might be interested in: Relay Sockets, IC Sockets and Headers, PIN Diodes
