Previous in Forum: Chemical Reaction Calculator   Next in Forum: Graphing Viscosity vs. Temperature
11 comments
Corrosion-Resistant Valve Materials
07/19/2009 9:22 PM
What material sould be used for valves against both H2S and CL corrosion
Re: corrosion
07/19/2009 10:31 PM
Give us a chance -
  • Pressure
  • Temperature
  • Concentrations
Re: corrosion
07/19/2009 11:46 PM
Tantalum.
Re: corrosion
07/20/2009 1:59 AM
What are your pipes made of? .............. do the same for your valves.
Re: corrosion
07/20/2009 2:36 AM
Re: corrosion
07/20/2009 3:00 AM
Actually, you need to provide the process condition, but in general, if the valve size is less than 2", disphragm valve would be a good solution, others could consider lining valve. Of course, the Tantalum is also a good one, but expensive, if your process fluid contains solid parts.
Re: corrosion
07/20/2009 11:13 AM
Thogh dry chlorine is not corrossive. Even it does not corrode carbon steel!!. We are using bellow sealed valves of PHONIX Armaturen-Werke Bregel GmbH make or Descot make. These are used in dry chlorine or liquid chlorine. For wet Chlorine PP lined with Teflon back with EPDM rubber diapharm valve are used. Of coarse the service pressure and temperature is limitation.
Re: corrosion
07/20/2009 11:36 AM
A titanium oxide film would provide resistance to both chemicals
Good Answers: 56
Re: Corrosion-Resistant Valve Materials
07/20/2009 10:47 PM
Try ceramic coated with Teflon
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
07/21/2009 9:03 AM
If you can use glass then aluminum borosilicate glass or at ultra purity needs quartz tubing is also good.
Metal you can use tungston coating on stainless steel
Masyood
07/21/2009 11:12 AM
Hastelloy with Teflon or PVDF Seats will work well with either Chlorine, wet or dry, and H2S, wet or dry.
08/03/2009 4:04 AM
Look at NACE / ISO 15156 for Sour Service Materials in Oil & Gas or NACE MR 103 for sour service in refinery
S
corrosion control
Anonymous Poster (5); Laughing Jaguar (1); Mark Jen (1); Masyood (1); PWSlack (1); RcEe (1); strider6 (1)
