Previous in Forum: Pipe Stress Analysis   Next in Forum: Gas Compression Solution
10 comments
Good Answers: 119
Wanted: NAS1765-3 Nut Plate
07/20/2009 10:03 AM
I'm having trouble finding a source for a self-aligning (spherical) nut plate. It's an NAS1765-3. If anyone has a clue where to purchase these in small numbers, I'd appreciate the source.
I've sent emails off to a couple of potential sources but not gotten any responses.
Thanks,
Hooker
Re: Wanted: NAS1765-3 Nut Plate
07/21/2009 8:55 AM
I suggest you check out Aircraft Spruce or other aircraft hardware supplier.
Good Luck !
Good Answers: 119
07/21/2009 9:22 AM
I've already checked all the usual sources like Aircraft Spruce and Genuine Aircraft Hardware.
Thanks for the response.
Hooker
07/21/2009 10:28 AM
Go to usbid.com and plug in your part number and it is there. You will have to give them a quantity and will then recieve a bid or price.
Good Answers: 119
07/21/2009 10:54 AM
<sigh> $300 minimum order on usbid.
I only need a few.
Thanks,
Hooker
Good Answers: 68
07/21/2009 8:12 PM
Hello Hooker,
I have found a couple of sites. However, I notice they are for use on Aircraft. I can therefore not recommend any single item. But I will give you the relatively short search results. You can then choose a company as you know exactly what you need. The first ref' is CR4. And it was the next one I looked at. They have your reference of NAS1765 - 3
But I will not advise you as I am not familiar with these. You can see from the google search shown below the search field and when you paste it into the address field you will see there is only two sites apart from the CR4 site. Hope this helps.
http://www.google.com/search?hl=en&client=safari&rls=en-gb&ei=61VmSor6MM-MjAej7-GoAQ&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=NAS1765-3+self+aligning+spherical+nut+plate&spell=1
07/22/2009 11:18 AM
Try these guys http://www.beconsumables.com/cm/products/products.cfm
Good Answers: 68
07/23/2009 4:14 PM
Hello Wingnut,
Hopw you are well?
With your 'name' I would be surprised if you are not the most likely to find this particular item! ;=)
Good Answers: 68
07/23/2009 4:28 PM
Hello Hooker,
Can you tell me via PM if you want, where your nearest large Town is, and how many fasteners you need?
I can then write to various sites and or people to request info'?
Good Answers: 119
07/24/2009 9:12 AM
Hi Babybear,
Thanks for your input.
Our purchasing department has found a source for the nut plates so I can move on with the project.
Hooker
Good Answers: 68
07/24/2009 10:11 AM
I appreciate your reply post. Thanks you.
Register to Reply 10 comments
Anonymous Poster (1); Aviator (1); babybear (4); Hooker (3); raggededgge (1)
