How to compress H2 + CO2 to 600 psi, 10 cfm max. 've looked at gas boosters - pricey, hard to control, and we'd prefer an electrical power source (vs. compressed air).
Most manufacturers we've talked to require a LONG lead time and will essentially be custom-building for us - so it's also pricey.
(I'm VERY open to a clever solution involving some creative adaptation of off-the-shelf stuff. I have *some* fabrication ability (very small CNC 3-axis mill, lathe, an expert welding guy, etc.) I've been thinking about adapting a bunch of small hydraulic 'bottle jacks' -- 5 1/4" stroke, 1.25 dia piston, 6 ton -- in some kind of multi-stage manifold, as just one example. In any case, key problems are the seals and heat dissipation - although we want the gas reasonably hot...)
Any pointers to either an off-the-shelf solution from a manufacturer, or pointers to some creative ideas that have been tried, would be MUCH appreciated!
