This is possibly an overly-complicated way to deal with a problem - but I think it is the 'cleanest' way.
For some grape vines, I installed two 4" round posts 2.5' into the ground, 30lbs of cement went into each hole at the bottom around the wood posts. They are 16' apart (actually... 189.5"), in heavy clay soil.
Now, to prevent the posts from leaning inwards when the wires are tightened, I had the 'bright idea' of using a single metal tube at the top (with flanges to hold it to the wood).However, aluminum tubing is expensive*, and I feel this may not work as I expect. I'd really like to use an unsupported span of metal tube. So I spec'd out two affordable sizes of metal pipe/tube:
1"x1" .125" thick 6061 Al, square
and
1 1/2" Schedule 40 6063 Al, round
Calculating the maximum deflection:
Square: .008"
Round: .002"
This just doesn't seem right. For 190", I would have to imagine the pipe would deflect an inch or two, but this indicates that it will deflect some, but not a lot. My biggest concern is if the tube deflects a lot (.5" - 2"), the compression between wires will cause the tube to bend even further.
Any thoughts? There are simpler ways to do this using wooden bracing, and additional posts, but I was hoping to preserver the clean look of the two posts.
*I chose aluminum because I'd like to avoid rust acssociated with galv or black iron pipe. SS is too expensive.
