Previous in Forum: Anti-Sparking Covers for Breathing Air Apparati   Next in Forum: Solution for Avoiding Green House Effect.
The Engineer
Good Answers: 129
Sun Tsunami
12/08/2006 5:02 PM
A giant solar flare created shockwaves that propagated around the Sun, destroying Sun surface features in its path.
"These large scale 'blast' waves occur infrequently, however, are very powerful," said K. S. Balasubramaniam of the National Solar Observatory (NSO) in Sunspot, NM, "They quickly propagate in a matter of minutes covering the whole Sun, sweeping away filamentary material."
http://news.yahoo.com/s/space/20061208/sc_space/scientistsspottsunamionthesun
Pathfinder Tags: solar sun tsunami
Re: Sun Tsunami
12/09/2006 7:46 AM
I didn't know the sun had a 'surface' as such...
As its one big gaseous ball of nuclear fission / fusion, I would guess that the 'surface' would be pretty mobile anyway!!
John.
Good Answers: 88
Re: Sun Tsunami
12/10/2006 2:00 AM
The "surface" of the Sun is generally (and arbitrarily) agreed to be the depth at which the photosphere is no longer transparent. But you're right, the Sun is gaseous all the way through, even at the core where the pressure is estimated at 3.4 × 108 atm to 2.25 × 1011 atm, and the density is about 150 times that of water. Even so, it is gaseous because of the extreme temperature, estimated at around 13.6 × 106K.
-e
Re: Sun Tsunami
12/10/2006 1:00 PM
Very interesting. Our Sun seems to getting very playful these days. This is sort of unusual (according to the scientists). But then again, this is the first time in accepted history that sun is being studied at this minuscle level. So if the Sun goes bump in the night, people are jumping out of their skins because they are seeing this for the first time.
This is definitely something to follow (aka 2012 connations also)
Register to Reply 3 comments
Anonymous Poster (1); Electroman (1); user-deleted-13 (1)
