I have a 99 Saturn with 155555 miles on it - Manual transmission (5 speed plus reverse). About a year ago, it started giving me trouble. After alot of stop & go driving in City traffic, it started having trouble getting going in first gear. Kept stalling. Engine seemed to be running well, and RPMs were functioning normally with the clutch depressed. Clutch feels normal, too. Just could not get moving. After being parked for a while (later discovered that short 5 minute rest periods would suffice) the problem seamed to correct itself. Took the car to the dealership (withhold comments please) and they determined that the clutch was fine. The car had a bad temperature and oxygen sensor, both of which should be replaced. Other issues discovered included a bad safety switch that requires the clutch depressed to start the car (never worked) and a rusted through muffler strap. Had the O2 and temp sensors replaced as possible causes. About a month later (September '08) the problem recurred. and has been on and off ever since.
Recently I discovered, while merging onto a highway, and downshifting to 2nd, that I had no power when releasing the clutch again (first major time in true motion). So I just drove it in 2nd with little to power until I was up to about 45/50 mph running about 3500 RPM - very unusual - should have been redlining. So I shifted to 5th and continued. Next time it happened - same day - I simply slipped into neutral, wiggled the gears left and right, back into 1st, and viola - success.
The bottom line - it seams that the gears are possibly getting stuck and and misaligning. I have had an issue with a squeeky clutch pedal for a couple years - which only occurs with alot of use. I think I am actually in 3rd gear, not first, which explains the lack of power. Has anyone ever heard of this occuring?
