Previous in Forum: What Is This Electrical Device?   Next in Forum: The AC System That Refuses to be Fixed
Relay Issue with High Voltage
07/22/2009 8:18 AM
i have problem in relay it works some times at normal voltage ,but after sometimes the relay high voltage for pick ....
what may cause for this problem....?
Re: Relay Issue with High Voltage
07/22/2009 8:36 AM
If it's a DC relay, one of the possibilities is the collapse of the magnetic field as the relay turns off. To suppress it, connect an appropriately-rated silicon rectifier reverse-biased across the terminals of the coil.
Good Answers: 53
07/22/2009 9:38 AM
This may be the case of poor design or not designed with min max analysis.
May be coil temp rises to too high, that leads to significant increase in resistance causing decrease in coil current.also this increase in temp will deteriorate the magnetic properties of magnetic path.
Every 100Deg increase in coil temp will add 40%(approx) on coil Resistance.
07/22/2009 11:01 AM
You should think before choosing a relay.Do you know how to choose a relay.
See the link :
http://www.4engr.com/forum/view_topic-pid-612.html#p612
Hobbies - Musician - Tube Amps Only Please!
07/22/2009 11:04 PM
Relay contacts can arc at high voltages and the contacts will get worst with time. But you need to give more data. What is normal and high voltage? How are you driving the coil? What current are we talking about? What are the ratings of the relay? What is the application? Post more detail otherwise it is difficult for us to help!
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
07/23/2009 3:47 PM
Is it not switching or switching and not making (or breaking) contact? Or is it making contact but has too high contact resistance (poor contact integrity)? Is the relay failsafe (returns to original position when de-energized) or latching (stay in selected position). Give us a clue and we can probably help you to resolve your problem.
What is right is not always popular. - What is popular is not always right.
maveric_manic (1); newaj498 (1); PWSlack (1); rakesh_semwal (1); U NO WHO (1)
