Previous in Forum: Circuit Problems   Next in Forum: Wireless Transmission of Power
Super bright white led wide angle
12/09/2006 3:24 AM
Can anybody help? I am looking for a super bright white wide angle LED for illumination purposes. 90/120 degrees would ideal. CPC had one but now obsolete. It also appears that there is a distinct lack of polar plots showing light distribution. Thanks for help
Good Answers: 120
Re: Super bright white led wide angle
12/09/2006 11:30 PM
They call that a lambertian distribution as it follows Lambert's law.
A frosted bulb is Lambertian, a naked filament is batwing pattern (not always)
some references on ebay
https://cgi.ebay.com/Brilliant-White-LED-Lumiled-Luxeon-LXHL-BWO2-Phillips_W0QQitemZ150069204645QQihZ005QQcategoryZ66952QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Per Ardua Ad Astra
Good Answers: 88
12/10/2006 2:43 AM
Many of Luxeon's super-high-power LEDs ( http://www.lumileds.com/products/line.cfm?lineId=18 ) have a Lambertian distribution:
A polar plot of the same thing looks like this:
-e
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
12/10/2006 5:26 PM
We actually have wide angle white LED Bulb. Admitted there has been some problems with certain LED applications, however depending on the exact application, and engineering, I'm sure you could make it work for your purpose.
Donald,
Campbell Lighting
Check out our home page for specs on "Soft Neon"
12/11/2006 5:59 AM
Hi Donald, I have a product using a small colour camera for inspection purposes. The FOV of the camera is around 95 degrees, so the nearer the o/p angle of the LED the better. I am looking for a conventional 5mm (ish) LED (not smt) that consumes <50mA. I have 4.8Vdc available. What are the limitations of your device (pdf file?) and cost. best regards, Andy
United States - US - Statue of Liberty - New Member
12/22/2008 12:10 AM
See here: www.elecosn.com
Here are dimmable LED Bulb, and LED incandescent bulb
12/11/2006 5:30 AM
Try http://www.dotlight.de/
They're very reasonably priced and ship to the UK no problem.
Register to Reply 6 comments
AndyH (1); aurizon (1); Campbell Lighting (1); ELECOSN (1); Randall (1); user-deleted-13 (1)
