Previous in Forum: Monoflanges   Next in Forum: Nylock Nuts
Thrust Needle Rollers
07/23/2009 1:34 AM
I am designing a turn table setup for new machine , to support the turntable plate shall I use thrust needle roller?
Otherwise what is the application of thrust needle roller?
Re: What is the use Thrust Needle roller?
07/23/2009 2:32 AM
SKF needle roller thrust bearings are fitted with a form-stable cage to reliably guide and retain a large number of needle rollers. The diameter deviations of the rollers within one assembly are within 2 µm, enabling these bearings to accommodate heavy axial loads and shock loads. These bearings provide a high degree of stiffness within a minimum axial space. In applications where the faces of adjacent machine components can serve as raceways, needle roller thrust bearings will take up no more space than a conventional thrust washer. They can accommodate axial loads acting in one direction only,
SKF supplies needle roller thrust bearings in several designs:
–needle roller and cage thrust assemblies, AXK series (fig)
–needle roller thrust bearings with a centring spigot, AXW series (fig)
For applications where adjacent components cannot serve as raceways, the assemblies can also be combined with washers of various designs.
Good Answers: 143
07/23/2009 8:10 AM
Again, there is insufficient information to answer your question. The trade-off between bearing types involves rotation, speed, load, shock, precision, allowable friction, cost, and lubrication (plus others that I have probably forgotten). There are a variety of turntable bearings available and you would do well to follow Guest 2's lead and contact an application engineer at SKF or possibly NTN.
