Hopefully, someone can help.
I am working in a electroplating factory. Usually, our drying parameter for EN (5-8 mcirons) on Diecasting parts is 65-70 deg C x 7-10 minutes. Recently, we find yellowish stain come from the milling surface after few days storage. My customer suspects that the parts are not completely dried and the water/moisture is trapped on the rough surface or inside the micro pores/porosity. The customer insists and instruct us drying the parts with 90 deg C x 15 minutes. We are using conventional oven with circulation. Our plating racks are seriously damaged under this high temperature and long time. Some of the PP/PE Coating blast out from the rack that the chemical can be trapped and contaminate the solution and the plated parts in the oven. Does anyone can tell, the 90 deg C x 15 minutes heating is the real root cause and the solution for the stain? By the way, I am using Twin Bed plus Mixed Bed De-ion Water System for final rinse. Thanks.
