I have to do some bolt torque, with 6'' flange 900# with 912 lbft,so I need to know pressure A and B, Please Could somebody explane ,how to calculate those pressures?
I'm quite certain that you're not looking for the gasket's "m" and "y" factors as inferred by others.
With all due respect, if you need "A" and "B" pressures, you won't be torquing the flange: You'll be tensioning it using hydraulically operated Bolt Tensioners.
Bolt Tensioning provides immediate bolt load rather than trying to attain it through an intermediate step of turning a nut (as done when torquing). As such, it is a much more accurate method of bolting used on critical joints (or on those where it's been difficult to achieve leak-free integrity) Here's a link for further information : Bolt Tensioning
The requirement for the "A" and "B" pressures suggests that the procedure calls for 50% tensioning.This means that half of the bolts on the flange will be tightened simultaneously. Once the the first set of bolts has been tightened, the bolt tensioners are indexed to the untightened fasteners where the process is repeated. One can see that this method of bolt tightening not only results in rapid flange assembly but, more importantly, it ensures even gasket compression.
The "A" and "B" pressures refer to the hydraulic pump pressures. The "A" pressure is a higher pressure than the "B" pressure. The reason is as follows:
When tensioning the second set of bolts, there will be some load relaxation in the first set. The "A" pressure is calculated to be somewhat higher than the "B" pressure so that once all of the bolts have been tightened, they are all under a consistent load.
The calculation for these pressures depends on
the desired bolt stress (this is where the "m" and "y" factors become important)
