Previous in Forum: Pressure A and B?   Next in Forum: Sourcing Little Clips
Bearing Designation
07/23/2009 10:46 AM
I have a motor bearing designation that I am not familar with. It is A54B0010-030. It is on the opposing drive end (ODE) of a GE motor with the following nameplate data: Model 5MR286yk2006, HP 20, RPM 1715, Volts 230/480, Type MR, Frame 286Z. The bearing designation does not correspond with all the references I have at my disposal. I would appreciate any information, especially whether they are open, shielded or sealed.
Good Answers: 16
Re: Bearing Designation
07/24/2009 6:37 AM
Have you checked the avalible GE sites? here is one for a 248 page motor catalog that might have some usefull information for you.
http://www.ge-energy.com/prod_serv/products/motors/en/downloads/SPCatalog.pdf
07/24/2009 6:58 AM
Thanks for replying. The catalog helps somewhat, stating that re-lubrication is required, but I still need to know the bearing size to calculate the amount of grease required and that was not available in the catalog.
Good Answers: 16
07/24/2009 7:31 AM
Well theres always option "B". As its only a 20 hp motor, just open it for a good cleaning and inspection. Then you can get the exact deminsions of both bearings.
Actualy on somthing of this size, I would lean toward replacing them with a good quality sealed bearing and replace them as needed.
07/24/2009 5:20 PM
Unless the motor is a special frame, the bearing is likely a standard size ball bearing. Measure the bore, OD and race width with a vernier caliper and look it up in any decent bearing catalog/data book for a match. We used to do this all the time when I worked in a motor rewind shop. note: Most modern bearings are sized in millimeters but there are still some inch sizes out there.
Register to Reply 4 comments
