Please refer to the Air Cond specification name plate. It has all the data's written in it including the compressor motor FLC.
Every 400 sq ft of room needs 1 ton, each ton needs 1.25 KW.
So, air conditioner is approximately 1.25 KW and the ampere is approximately 2 A. This is only a rough approximation, the actual KW and ampere depends on many other factors.
