Previous in Forum: UPS Sizing Formula   Next in Forum: Salvage Value of Electric Motor
Power Factor
07/24/2009 3:44 AM
Explain what is power factor.How is it controlled for maximum efficiency of multiple number of DG sets running in the sub ststion?
Re: Power Factor
07/24/2009 3:52 AM
Apart from cable sizing and breaking cast iron baths up, it is CR4's most popular topic.
Link.
Good Answers: 103
Re: Power Factor
07/24/2009 4:24 AM
Along with
50Hz-60Hz ?
Weight of MS beams ?
Why the generation is in multiples of 11 ?
Home work questions (look to be one here)
BTW:
a) Substation as far as I know do not have DG sets.
b) The power factor improvement has got nothing to do with number of DG sets- well not immediately, except in case of miscalculations and instability in the system.
Re: Power Factor
07/24/2009 6:22 AM
Quite.
Re: Power Factor
07/24/2009 5:28 AM
It's a home work.
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Re: Power Factor
07/25/2009 3:49 AM
What's a DG? (Dog Gone? Done Good? Diesel Generators???) Load? Hz? Lead Lag? Voltage? Amps? Location? KVA? KVR? Moon-rise time?? Sunset time? Tide high times?? Low tide?? Size of your shirt in metric!!!..... and power factor is based on the amount of current used by a motor over what is apparently being used by a motor of lagging current. It's kind of an efficiently thing. Degree angle of lag Cosine θ = P.F. You can run your gen sets with a certain degree of lead or add a set of capacitors.
Could be worse, it could be me. :)
mayt2u (1); PWSlack (2); sb (1); Simon Wan (1)
