Previous in Forum: Vendor Drawing - Pumps and Compressors   Next in Forum: what is the meaning of "slug rivet"?
Sourcing a Gearbox
07/24/2009 3:21 PM
Would you please help me to source 20MW Power Gearbox
Is it possible to operate gearboxes in series ( Tandem) to have more power if single unit does not have 20MW power
It's required for Nacelle testing feasility to test complete nacelle.
Please help me in this regard.
Re: Sourcing a Gearbox
07/24/2009 4:00 PM
This is easy to understand if you just become familiar with the relationships between torque, work and power. Please look over some basic materials like wikipedia or an entry level text book.
If you have a 20 MW power motor coupled to a gearbox, the gearbox could still put out 20 MW of power (assuming no losses). But the gearbox power out would be delivered at a different torque (higher if the gearbox is used as a reducer) and RPM (lower if the gearbox is used as a reducer) than the motor provided.
If you add another gearbox to the output of the first gearbox, the second gearbox could still put out 20 MW of power (assuming no losses). But the gearbox power out would be delivered at a still different torque and RPM.
Everything I know about opera I learned from Bugs Bunny
07/24/2009 7:23 PM
I am reading between the lines a bit and by tandem I think parallel not series.
Are you saying that by using two gear boxes you get a total of 20 MW? So each would Carry 10MW each?
Nacelle would indicate wind power usage possibly?
That is a common set up in industrial applications were two motors and gear boxes of lesser capacity do the work of one of larger capacity. This also works with driving two generators going the other direction with the power. But the generators if AC type would require some basic phasing and synchronization of their outputs in order to work as one larger generator. But yes it can be done.
07/25/2009 1:47 AM
Dear Sir,
If you give me the details regarding the output rpm required and direct load to be carried by the gear box and the application details, i can provide you the gearbox, suitable for your application.
With Regards !
S.Shaik Farid
EETA TRANSMISSIONS
mail me in eetatransmissions@yahoo.co.in
07/25/2009 1:37 PM
Hi , I am, not a member however I like the question. so here is my answer
Source only manuf. that meet rules and regulations, provide service, and are well known, ask for references that are similar or equal to your application.Your application is vital input for the right design.
Power, intermittent? load changes? constant? stand by?
Speed in/output, variable? constant? torque variabel? torque constant?
Environment land? marine? offshore?
Prime mover /driven equipment needs to be inline? Offset horizontal? Offset vertical?
Clutch required?, Integrated in gearbox? external? Hydr operated/air operated/electr operated?
Requirements for control/monitoring, pressure, temperatures oil/bearing/gradient monitoring, vibration?
Design gearbox, lightweight, welded casing, cast casing, dry sump/wety sump?
Gearbox driven oil pump? electric standby?
Simplex/duplex filters? Instrumentation, dP indication, alarm?
Available space?
Flex coupling prim/outgoing shaft design
Diesel engine involved? than make incorporate gearbox in the torsional vibration analysis.
Best regards
Jaap
Good Answers: 68
07/25/2009 8:45 PM
Hello sivam',
how are you?
================================================= (What you wrote)
Would you please help me to source 20MW Power Gearbox.
Is it possible to operate gearboxes in series ( Tandem) to have more power if single unit does not have 20MW power.
With the reference to Gearboxes, the speed at the 'final' gearbox has to be given some thought. I can perhaps understand the use of smaller, lighter, gearboxes, which allow for, maybe two or three in a row?
This can keep the total drive speed down in the first couple of boxes, which will last longer because of this. The 'final' gearbox could be the one which could perhaps be a more simple affair with say, one or two ratios? And it
could be the one to be replaced and maintained at a more regular interval? Does that make sense to you?
With regard to the nacelle testing............
It depends on the exact use you intend for the 'Nacelled' (if that is the correct term) Motor and gearbox/es? If they are to be in an aircraft then for sure they should be tested. If, on the other hand you are asking maybe of a Wind Mill, I would have thought that you could use an already manufactured Nacelle?
You could build a good strong floor or base to carry everything and, of course to allow access to the gearboxes and Motor for maintenance. You would essentially building a small room but up high.
I will not say more until I see what you have in mind, but it does sound interesting.
All of what I say is guessing as I do not know the final use of the motors and gearboxs, OK?
http://www.google.com/search?client=safari&rls=en-gb&q=gearbox+for+20+megawatt+motor&ie=UTF-8&oe=UTF-8
Results 1 - 10 of about 25,000 for gearbox for 20 megawatt motor. (0.30 seconds)
Sponsors Results:
Buy Online - Fast UK Delivery
www.bearingboys.co.uk/Elec_Motors gears
www.delaimotor.com
Compact Geared Motors
Type Compacta for Reversing tasks
Torque up to 600Nm; Speed up to 193
www.Framo-Morat.com
Looking for gear boxes?
Design and manufacturing
of gear boxes up to 350.000 Nm
[n]www.pulsgetriebe.de
Find A Gearbox
Gearboxes For All Makes & Models
New Used & Reconditioned Units
www.findagearbox.co.uk
Free Gearbox Finder
Search 100's of the UKs Breakers
to find Gearboxes at Great Prices
www.breakerlink.com/Gearbox
More Sponsored Links »
Sponsored Links GearBoxes Stocked
www.gearboxexchange.co.uk
All types of manual Car gearboxes are in stock and ready to fit motor gearboxes
www.bonmet.de/English/index.asp
High quality motor gearboxes, dedicated to reduce field.
Need a new Motor?
www.edmr.co.uk
Stock motors up to 200kW Next and Same day Delivery
================================================ Search Results
New roles<br> for permanent magnet technology - Motors and Drives
Getting rid of the gearbox and brushes not only reduces maintenance requirements ,
... The typical power range of these motors is 400 kW to 20 MW. ...
www02.abb.com/.../33D2103E6CE41873C1256E9900424ABE -
Cached - Similar -
Hutter Putter™ Variable Speed Rotor Turning Drives Provides additional speed reduction for turbines 500 MW and larger with vertical turning gear motors. Hutter Putter Gearbox replaces ...
www.hutterent.com/putter.html -
Cached - Similar -
[PDF] OPTIMISED GEARBOX DESIGN FOR MODERN WIND TURBINES
File Format: PDF/Adobe Acrobat - View as HTML
2.2 MW Tjaereborg. DK. 2000. 1.5 MW typical wind turbine gearbox design ....
auxiliary motor generator whose rating is 15/20 % of the main generator needs ...
www.2004ewec.info/files/23_1400_rayhicks_01.pdf -
Similar -
NKE modular bearings used in wind turbine gearboxes - Motor & Drives
1 Jul 2009 ... Pittman launches G30A planetary gearbox for DC motors (17/03/2009).
All quiet on the planetary front (20/02/2009) ...
www.motorsdrives.com.au/...in...gearboxes/488861.aspx -
Cached - Similar -
AC Motors Manufacturers,AC Motors Manufacturers Directory,India AC ...
Manufacturers of Pmdc Motor, Ac Motor, Gear Box, Worm Gear, Reducer, Disco, ...
Ac Alternator 2 Mw to 20 Mw, Ac Motor 5 Mw to 12 Mw Any Voltage Range upto ...
www.indianyellowpages.com/india/.../a/ac-motors.htm -
Cached - Similar -
Endless-sphere.com • View topic - Deal on a gearbox.
10 mW: Posts: 20: Joined: Thu Apr 02, 2009 5:12 am: Location: Rockingham, ...
Subject: Selecting a gearbox for motor assisted mountainbikes. ...
https://endless-sphere.com/forums/viewtopic.php?f=28&t... -
Cached - Similar -
Damping motor and control approach for mitigating torsional ...
Motor 1 and motor 2 are each 2.5 MW variable speed motors capable of producing ...
motor 20 load shaft 24 prime mover 26 reduction gearbox 28 load 30 input ...
www.faqs.org/patents/app/20090049941 -
Cached - Similar -
Used Power Plants, Diesel, Hfo, Gas Turbines, Steam Turbines ...
Our Offer No: Sidra-6010-52 Mw-man-hfo 52 Mw Man Hfo Power Plant ....
lilykamarks, Wed 25 Feb, 2009 3:20 am, gearbox is made in china it can be used for ...
www.traderscity.com/.../used-power-plants-diesel-hfo-gas-turbines-steam- turbines-lufkin-gearbox-power-barages-10792/ -
Cached - Similar -
Turbine generator set without a step-down gear box - US Patent ...
Gas turbines providing low or medium power (a few MW to a few tens of MW) are
.... the measurements being taken by means of measurement transformers 19 and 20 .
... and it requires a step-down gear box 12, but the starter motor is ...
www.patentstorm.us/patents/5694026/description.html -
Similar -
Searches related to: gearbox for 20 megawatt motor wind turbine gearboxes planetary gearbox
Anonymous Poster (2); babybear (1); DaveB (1); tcmtech (1)
