Previous in Forum: Flow Lines for Nitrogen and Diesel   Next in Forum: Increasing Torque and Speed
9 comments
India - Member - New Member Germany - Member - New Member France - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Engineering Fields - Energy Engineering - New Member Hobbies - RC Aircraft - New Member
Servo Motors and V12 Engines
07/26/2009 1:38 AM
What is servo motor? What is firing order for v12 engine? Can i run petrol/diesel engine using compressed air?
Be an engineer not a degree holder!
Re: Servo Motors and V12 Engines
07/26/2009 11:16 PM
A servo is a smaller usually electric motor used to operate some remote device. As for the firing order of a V12 engine it depends upon who's engine it is! Not all engines have the same firing order!
07/27/2009 2:11 AM
Yes u can run petrol engine with the help of compressed air but most suitable application to run on compressed air is air motor which might be more efficient than petrol engine.
07/27/2009 5:40 AM
Hi the firing order of the jaguar v12 engine is
1A 6B 5A 2B 3A 4B 6A 1B 2A 5B 4A 3B
A=right hand cylinder bank
B=left hand cylinder bank
07/27/2009 7:20 AM
servo motor is type of motor may be AC or DC.
having quick acceleration and deceleration ability.
the torque at any RPM is constant.
in servo u can get perfect angular position of shaft.
this motor are mostly used in automation.
07/27/2009 7:21 AM
just go through below link
http://www.seattlerobotics.org/guide/servos.html
KIRAN G
Good Answers: 12
07/27/2009 8:58 AM
If you really want to use a gas engine for an air motor or a compressor you will have to design a custom cam for it. I remember a kit that turned a Volkswagen engine into a self powered air compressor by using one bank to supply power and the other side to pump air. It does work. That kit did include a special cam.
07/27/2009 9:59 AM
What makes any motor a servo motor is the application of negative feedback to control the motor. DC electric motors are some of the easiest motors to do this so they are often labeled as a servo motor but it's applying the negative feedback itself that makes it a servo motor. The engine and transmission system of many of todays cars become a servo motor when in cruise control.
Good Answers: 123
07/27/2009 11:26 AM
Firing order for Detroit Diesel V-12 engines is different for RH and LH rotation.
RH = 1L-6L-3R-5R-3L-5L-2R-4R-2L-4L-1R-6R
LH = 1L-6R-1R-4L-2L-4R-2R-5L-3L-5R-3R-6L
Rotation is as viewed from the front of the engine. Good luck.
Bob
07/27/2009 8:41 PM
a servo motor is a device which can move a specified amt when sent the appropriate signal. These are often used in radio controled model planes. Of course they are also used in industry where precise control is necessary.
Register to Reply 9 comments
Anonymous Poster (3); bob c (1); kiran001 (1); livagain1 (1); Rebuilt (1); redfred (1); snuf (1)
