Previous in Forum: Concrete Water Tank Leaking   Next in Forum: Finding a Hidden Drain in a Concrete Floor
8 comments
Reinforced Concrete Shear Walls
07/26/2009 11:13 PM
I need to get a software for reinforced concrete shear walls. Any suggestion?
Re: reinforced concrete shear walls
07/26/2009 11:17 PM
Found this by searching:
Search this Forum
Home | Civil Engineering | Civil Engineering | shear wall | Re: shear wall
Rate this Comment:
ba/ael Guru
Join Date: Nov 2007 Location: Sherwood Park, Alberta, Canada Posts: 836 Good Answers: 38
Find in discussion
Re: shear wall 05/11/2008 9:28 AM
  1. Shear walls may be used in single storey buildings or high rises. Shear walls are intended to resist lateral forces such as wind. Other methods include rigid frames, braced frames and shear walls combined with rigid frames.
  2. There is no exact location for a shear wall, but some arrangements are better than others. It is desirable but not always possible to have shear walls on the exterior walls because they offer good torsional resistance for the building as a whole. Usually the architectural requirements will have a bearing on the location of shear walls. A wall which is largely windows is not a good candidate for a shear wall.
  3. Shear walls are connected to horizontal diaphragms such as floors and roof. How to connect depends on the type of shear wall, i.e. wood stud with drywall or plywood, reinforced concrete, concrete block or steel plate. The connections must be adequate to resist shear forces resulting from applied lateral loads.
Bruce
Good Answer (Score 2)
07/28/2009 10:37 PM
Thanks for your comments, I appreciatte
Re: Reinforced Concrete Shear Walls
07/27/2009 9:45 AM
What do you need to the software to do? What calculations do you need?
Good Answers: 213
07/27/2009 11:05 PM
Check out http://www.structurepoint.org
07/28/2009 8:32 AM
You can look this page over http://www.strongtie.com/products/strongwall/steel-strongwall/index.asp?source=hpnav It's from Simpson Strong-Tie. They make hardware for wood framing and Engineered Roof trusses and walls. And they have tables you can use for Load and Stress requirements (Snow, Dead, Wind, Live load ect). AutoDesk Revit software might support Stress analysis tests for buildings. And their AutoCad Civil software would help for Concrete retaining walls on roads and such. You can phone Simpson Engineering tech support @ 800.999.5099. They have a very knowledgeable staff and I'm sure they can stear you to the right place if they can't help you.
Ed
07/28/2009 10:38 PM
Thanks a lot, I will check it out
07/28/2009 11:11 AM
I found this site using a simple browser search. They have a multitude of structural design & analysis spreadsheets (but I've never used them). I believe reinf. conc. shear-walls are included.
www. engineering-international .com
good luck
07/28/2009 10:44 PM
I download a demo ( shear wall forces) , maybe it`s what I`m looking for. Thanks
Register to Reply 8 comments
Anonymous Poster (2); BrooksCadd (1); constructor ant (3); cwarner7_11 (1); lyn (1)
You might be interested in: Retaining Walls, Curtain Walls, Force and Load Sensors
