Previous in Forum: Passivation on Electroless Nickel Plating   Next in Forum: Diesel Turbine Generators
Welding Rod Consumption
07/27/2009 8:04 AM
Hi!
Is there any formula for calculating welding rod cosumption per running mtr?
We use 6013 rod ; first with 3.15 & then 5.0 in 2G position. normal fillet weld say 10mm.......
Re: Welding Rod Consumption
07/27/2009 5:10 PM
You best bet is to calculate the cross-sectional area or your typical weld, and then calculate the volume. Depending on the shape of your 'normal' fillet weld, it could vary by quite a bit. We used to do this in a piping shop I worked in... calculate lbs of rod for a 3" sch80 CS weld, lbs of filler and CF or shield gas for a 4" SS TIG weld, etc.
Reply to Forum Thread
