Previous in Forum: Airless Paint Sprayer   Next in Forum: Bending Radius of Steel Tube
Residential Hot Water Heaters
07/28/2009 12:11 AM
Does anyone know of a manufacturer that makes a 52 gal.??? residential hot water heater with a refrigerant coil in it.
Archers arrows
Re: HEAT PUMP HOT WATER
07/28/2009 12:47 AM
Why would anyone put a "refrigerant coil" in a "Hot Water" heater?
Could you share your application --- we won't tell anyone we promise.
Gavilan
07/28/2009 3:42 AM
Use a UK domestic copper immersion cylinder with a coil for an external heat source like a central heating boiler, and pass a cold utility fluid through the coil. B&Q or Wickes keep them in stock <usual disclaimer>.
Beware the pressure rating of <0.5barg on the cylinder.
07/28/2009 3:16 PM
TO CUT THE COST OF HEATING THE WATER AND REDUCE CO2!!!!!!!!!!!!
give me a name PWSlack
Archers arrows
07/29/2009 1:50 AM
Sounds like a good loop for a Solar application!!!
07/29/2009 2:05 AM
No The new heat pumps use a scroll pump and variable speed DC motor. The mini-split systems divide the house into zones and pump only what is needed. the hot water heater is a zone, cutting the electricity needed by up to 70%.
I still need a name
Archers arrows
07/28/2009 3:49 AM
Coils in tanks are so inefficient,a brazed plate heat exchanger with water one side and the other acting as the condenser would be far better.
Register to Reply 6 comments
_Leon_ (1); archer (2); Gavilan (2); PWSlack (1)
You might be interested in: Hot Stamping Foils, Hot Runner Controllers
