Previous in Forum: Oil Filtration   Next in Forum: Tension Control For Paper Roll
Material Mill Test Certificate
07/28/2009 11:48 AM
i have be attack by my project engineer.
the materials supplied by contractor for the gas header extension work were outsourced locally. the contractor could not get mill test certificate for them an beacause i have inspected visually and they are good condition and also meet piping Code acceptance material, i give go ahead to use the materials.
my question now is what is the effect of no mill test certificate on the work?
Re: Material Mill Test Certificate
07/28/2009 1:21 PM
Not much, unless you have a failure that causes personal injury. Then your insurance company (if you have one) will not cover the accident. And you, by signing off on an uncertified job, will be liable. Depending on local laws.
Since we have no way of knowing where you are we can't help much.
Good Answers: 103
07/28/2009 1:47 PM
I am sorry, but as per our standards we insist on the material mill certificate and even the re-test and others are not enough for us. And this is not only for our pressure vessels but for other critical fabrications (with high stress) too.
08/30/2009 5:11 PM
Not knowing what country your are in, or what area, MTR's are a basic requirent of most Quality control certifications. These qc programs are most usually governed by a ruling body administered by local and federal government. A manufacturer must supply these and can be traced by heat numbers assigned to material. If they are welded fittings, design requirements must meet a required Carbon co-efficient. these are listed on the MTR's. If not it is up to the governing body as to wheter this lack of information is acceptable, probably not. Check with the governing body in your area on welded materials as with the contractors own Quality Control Program.
lyn (1); Navillus (1); sb (1)
You might be interested in: Milling Machines, Lighting Design Services
