Previous in Forum: Security Against Piracy at Sea   Next in Forum: Monopropellant Powered Free Piston Hydraulic Pump
9 comments
Algae in U/G Holding Tanks
07/28/2009 6:00 PM
Hello,
I work for a potash mine and we pump surface water to 1,000 gallon holding tanks underground, to be used for dust control on roadways and at mining face equipment. We are having problems with algae, both causing smell and plugging filters. We are looking at doing some kind of injection pump setup that will either pump chlorine, brine (salt water) or any other solution into the water to help control the algae. I am looking for any information on what pump/system to use, if chlorine or brine is better, how many ppm of chlorine/brine we'll have to use, etc. I would appreciate any information or some where I can go to obtain some info. If you need any more info, or have any questions, feel free to reply.
Thanks
Re: Algae in U/G Holding Tanks
07/28/2009 6:13 PM
Try these www.derwentwatersystems.co.uk
Do you mine under the sea?
07/29/2009 11:55 AM
No, we mine potash out of Colonsay, SK, Canada. The water is just pumped from an open surface pond to u/g holding tanks.
Good Answers: 101
07/29/2009 5:03 AM
Chlorine. Brine must be highly concentrated to be effective, whereas a free chlorine level of 1ppm will keep your water clear.
07/30/2009 1:34 AM
Hello,
Chlorine is definitivly the best solution, but keep in mind that it must be mixed well with the water in the tank and also that it will stop being active after about 2 - 3 days (depending on temperature and organic content of the water). 1 ppm is good to start with - just make yourself aware of any environmental restrictions regarding the use of Chlorine.
I suggest to either add the chlorine into the filling up line for better mixing or if you have enough flow through in the tank you might also think about using those tablets that are used in swimming pools.
Good luck
07/30/2009 4:11 AM
If the tank is kept under pressure alge growth is reduced and clorine works much longer.
The lack of pressure in the tank allows the alge to grow fast. I doscovered this on a sail boat years ago. Adding just 20lbs of pressure to the tanks cut the alge growth and we used a lot less clorine too.
Good Answers: 213
07/30/2009 10:58 AM
I use ozone to control algae in stored water. Set up a recirculation system, inject ozone into the recirculation line. Less environmental impact than chlorine or brine, especially if the water escapes to the aquifer.
Good Answers: 101
07/30/2009 11:03 AM
UV will also do the trick, and you don't need to worry about escaping ozone.
08/03/2009 8:54 PM
treat the pond before drawing the water into your holding tank.
see www.killlakeweeds.com
Good Answers: 97
08/03/2009 9:12 PM
Add potash to water increasing the alkalinity above that which supports the growth of algae.
_Leon_ (1); Anonymous Poster (2); bwire (1); cwarner7_11 (1); dadw5boys (1); DVader1000 (2); maxig (1)
