Previous in Forum: Air Quality Analysis   Next in Forum: Is There a Formula for Magnetic Repulsion?
Axial Load on Horizontal Francis Turbine
12/11/2006 12:30 AM
I would be pleased, if some can help me by giving guidance to calculate axial load on Horizontal Francis Turbines.
Available techincal data,
Maximum power put put _1.4 MW
Runner Diameter _ 430 mm
Shaft Diameter _ 250 mm
Best Regards,
Asitha from Sri Lanka
Re: Axial Load on Horizontal Francis Turbine
12/12/2006 7:50 AM
The upstream minus the downstrean pressure times the area of the vanes and hub plus any mass load from the vanes.
Area in^2 x pressure delta in psi = lbs force.
Mark Howell
02/05/2007 8:39 AM
I agree. Francis turbine is basically not subject to dynamic loads during work. So, the statement looking for pressure differential plus mass loads is correct. I think this would be the main doubt.
PS: also, you can use SI units: kg, N, m, Pa (= N/m2)
Humm... suspicious you are...
Register to Reply 2 comments
