(Reposted from the General Section to the more appropriate (?) Electrical Engineering Section)
Would anyone be so kind as to clear up hi-pot testing for me?
I understand that in CE countries the "rule of thumb" is to test at 220V*2+1000V = 1500V (rounded up). It's the duration requirement I don't understand. I see both 1 minute and 1 second commonly mentioned.
I was under the impression that you have a choice of those two durations, but if you chose the longer one you could reduce the voltage to say, 500V or so. The higher voltage / lower time option was a concession to increase manufacturing throughput.
However I've also been told that whether you test for 1 second or 1 minute, the 1500V always applies.
A little clarification please?
