Previous in Forum: Restoring an Antique Barber Chair: The End is Near (I Hope)   Next in Forum: Home Built A/C Mister
Radiation- Internal/External?
07/29/2009 7:25 PM
Lets start with a house radiator. If it is painted(lets say one coat each) silver, does the silver reflect any of the heat back into the radiator thereby reducing the amount radiated? Or does it reflect more heat out? The same question with a black radiator does it absorb more heat from the source and not reflect it out? I can recall from having steam radiators in a house the silver seemed hotter, but I never measured either of them. As we know the darker object gets hotter in sunlight,but what about internal heat ie; steam, hot water? Aside from actually doing the test , has anyone done this and what was your result? Thanks, Hank
Re: Radiation- Internal/External?
07/30/2009 12:46 AM
When I worked in the aerospace/satellite industry, we painted all our various electronic enclosures inside the space craft with flat black paint.
Out there, we didn't have any convective heat transfer, no air.
My guess is that this would hold true in Earth's atmosphere, but the air here would also distribute the heat more evenly.
I don't do thermodynamics.
Maybe Vader knows. He wears black, you know. Of course with him, it could be a style thing.
07/30/2009 3:38 AM
Despite its name, a radiator does rather less radiating than it does convecting. So the strongest quality of the paint has to be that it is highly thermally conductive. Its colour is of little relevance.
To improve the performance of a wall-mounted radiator, the easiest way to do it is to place a retroreflective surface on the wall behind it, preferably with a thin layer of insulation between that surface and the wall.
Commercially-available materials may be had at any major home improvement outlet, and are relatively inexpensive.
