Previous in Forum: difference in between material M.S(mild steel) andA105   Next in Forum: HYDRAULIC CYLINDER.
Air Receiver Size for Compressor
07/30/2009 6:08 AM
Dear All,
I have 2 units of centrifugal compressor with 50m³/min which is equal to 100m³/min at 70Psi for my glass forming processing machines. Right now i have 2 units of 3m³ air receiver tanks which is connected via dia 6 inch pipe with distance of 10m away from compressors unit.
Pls advise me do i need a big size of air receiver to accommodate the air from compressors.
Thanks and regards
Re: Air Receiver Size for Compressor
07/30/2009 10:59 AM
Air Receivers are not even used by some on Rotary type compressors as ecommended by the manufacturer.
OTOH the Receiver may need to be oversized when a circuit uses a High Voume of air for intermittent, short, high flow situations. An oversized receiver in that case may be located close to the operation using the short high flow demand.
Bud Trinkel
07/30/2009 11:25 PM
The size of the receiver is all to do with the demand cycle as stated by BudT and the method of control of the compressor, on/off, venting, speed etc etc.
You do not want your compressors switching on and off every few minutes. Are you sure these compressors are centrifugal, at these volumes and pressures I would expect rotary.
07/30/2009 11:57 PM
THe following table was taken from Kaeser/useful tools web site it gives an indication of factors to consider when sizing a receiver if you go to the site and enter the variables it will come up with something close to what you will need.
Sizing Air Receiver
Please use a decimal point and not a comma to indicate the decimal place!
SI - Units US - Units
Calculating as a buffer
Calculating according to permissible cut-in frequency
Required flow rate V m³/minRequired peak load flow rateV
m³/min
Buffer time t minFAD of the largest sequenced compressor* V
1
m³/min
Initial receiver pressureP
I
barCut-out pressureP
max
bar
Final receiver pressure P
F
barCut-in pressureP
min
bar
The additional delivery of the compressor is not consideredPermissible cut-in-frequency** Z1/h
Utilization factor:***A %
V2 : V1
Receiver volume V
R
m³Receiver volume V
R
m³
*This is usually the peak load compressor in multiple compressor installations but the calculation can also apply to base load machines. In general, the larger the air receiver, the better and smoother runs the compressor station.
**Maximum permissible cut-in-frequency per hour of the largest switching compressor. Guide figures: Compressors up to 18.5 kW Z=120, up to 75 kW Z=60, over 75 kW Z=30.
***Critical case: Compressors must switch most frequently when they are run at 50% duty cycle (utilizaton)
Utilization factor A = (V
2/V1) = 0.5
08/03/2009 6:27 AM
Hi Grochy,
Thank you very much of your very useful info.
Regards
Register to Reply 4 comments
aikhh (1); Anonymous Poster (1); BudT (1); Grochy (1)
