I forgot my password.
Don't have an account?
HOW SHOULD I USE A CYLINDER WHOOSE SEAL KIT ARE DAMAGED, FOR A SHORT WHILE AS THERE IS NO STOCK OF KIT IN HAND AND THE MACHINE SHOULD NOT BE STOPPED?
As the leakage is too loud, I don't think you have any option but to stop it.
Many factors to consider, however, if the machine still functions SAFELY and makes good product I would run it. The main problem is HEAT GENERATION can/will increase so make sure the Heat Exchanger can remove the Excess Heat.
Safety is your first concern.
You didn't tell us where the leak is or how badly it's leaking..
