Previous in Forum: Impedance Voltage for a Transformer   Next in Forum: AC Controlled-Current Stimulator
8 comments
How to Select Cable Size For 7.5KW Induction Motor
07/30/2009 11:47 AM
Dear sir;
I want to know selection of cable size for induction motor.
Re: HOW TO SELECT CABLE SIZE FOR 7.5KW INDUCTION MOTOR
07/30/2009 11:50 AM
dear,
dol starter motor requires 3 core * 4 sq mm Copper Armoured cable.
07/30/2009 5:53 PM
Quote "dol starter motor requires 3 core * 4 sq mm Copper Armoured cable."
How can you say this with out knowing the voltage?
04/25/2012 7:57 AM
we can use 3core, 2.5 sq mm cable for dol starter motors.
01/23/2024 2:58 AM
The <...we...> needs to assure compliance with the applicable local electrical standard. First.
Re: How to Select Cable Size For 7.5KW Induction Motor
07/31/2009 6:15 AM
For three phase AC motor( 415 volts,starter:DOL) 3 core x 4 sq.mm cu.conductor armoured cacle shall be used. for single phase motor (230 Volts) you can use 6 sq.mm x 3core CU. conductor cable to be used .For 110 volts motor, you can use 10 sq.mm x 3 core cu.cable. O.k All the best.
08/03/2009 3:05 AM
Use British Standard 7671, then.
10/04/2010 3:46 AM
how we can calculate the Busbar size for electric panels.
If some one have a knowledge of this.
Please Explain.
05/04/2012 5:34 AM
That topic has been done to death on CR4, as entering the words "busbar sizing" in the "Search all of CR4" box to the right will reveal.
Anonymous Poster (2); lavurk (1); PWSlack (3); V S Reddy (1); wareagle (1)
