Previous in Forum: Preparing Used Cooking Oil   Next in Forum: Solidworks Human Figure Model?
Good Answers: 12
Excel Assistance Please
07/31/2009 1:23 AM
Hi. I need help in designing an excel spreadsheet. I'm not a uni student...I am trying to implement this at work. Here goes;
I have a list of 8 digit serial numbers in one column. In another column i have a list of assigned product names (which happen to be numbers). I need to assign a MAC address (in HEX format) to specific products that require them. The MAC address that is used should come from a list where the MAC addresses are listed numerically. In other words, we bought 2 blocks of MAC addresses from IEEE (that's a number of millions of MAC addresses) and there should never be a double-up.
Now I created such a file with relevant formulas so when i type in the next available serial number with a specific product, up pops a MAC address. If the product does not require a MAC address then it's blank. It works fine but the method is frought with danger. If someone decides to alter a previous entry or change the product name, all preceding assigned MAC addresses will change. It should not happen, but there is always that possibility currently.
I'm sure there is a better way to do this and am asking for your help. Any ideas?
Re: Excell Assistance Please
07/31/2009 9:49 AM
Not knowing exactly what your mean my someone changing a product name, but you can lock the cells so they can't change them, you can password protect your cells from change as well.
Would that help?
Good Answers: 204
Re: Excel Assistance Please
08/01/2009 11:28 AM
Due to the implied criticality, I would recommend that you do not use excel. Use a programming language. (ie: vb) At the very least, write the function of it in VBA in excel. I believe there are ways of locking the sheet.. but you need to provide some screenshots of what you are trying to do.
Chris
Good Answers: 97
08/02/2009 3:42 PM
08/02/2009 7:11 PM
Try this and you may find some useful tips in http://excel.tips.net/
Continuous Learning
08/03/2009 8:54 AM
VBA in code behind would be the way to go. Rather than plugging a formula into a cell you can call a subroutine and insert a value into the spreadsheet. This would prevent recalculation when an edit was made on the sheet. Perhaps the formula could protect the cells from change.
Sub protect()
Range("A3:A12,D3:E12,J1:R13,W18")
Range("W18").Activate
Selection.Locked = True
ActiveSheet.protect Contents:=True
End Sub
Or something similar would do the trick.
bwire (1); chrisg288 (1); Daddio926 (1); Labyguy (1); sv13 (1)
