Previous in Forum: 1000toe of natural gas correspond how many GWh electricity?   Next in Forum: About back emf
Lighting
07/31/2009 6:53 AM
Is it necessary to use flameproof fixtures in humidification plants in textile industry?
Re: Lighting
07/31/2009 4:53 PM
Suggest you check your local electric code for this answer.
Re: Lighting
08/01/2009 3:00 AM
hingorani1971,
Of course 'necessary' is relative to your local code requirements, but I think you are more trying to understand why flameproof fixtures would be required in a humid environment.
Dusts being explosive is of course the root cause, but humidity alone does not remove the threat since it may not be universally or evenly distributed. CJM
I do not 'know it all', but i will admit that I would like to. CJM
Re: Lighting
08/01/2009 4:11 AM
It depends on the hazardous area zone classification of the areas of the plant the lights will be placed in. If the area is not a hazardous area (now more commonly called flammable atmosphere area) then the fitting needs to just be rated for the environment (such as having the appropriate IP 'Ingress Protection' rating).
This answer is a very general one given the information you have given. Can you please provide more information.
Re: Lighting
08/03/2009 2:59 AM
It is necessary to use hazardous-area-rated equipment, to the relevant section of the applicable code for the hazardous area zone, wherever a potentially explosive atmosphere exists.
Register to Reply 4 comments
CJMcGill (1); jack of all trades (1); PWSlack (1); wareagle (1)
