Previous in Forum: Von Mises Equation and ASME B31.8   Next in Forum: heat exchnagers
Good Answers: 16
How to Build a Slack Tube
08/02/2009 8:28 AM
Hi CR4 friends,
I'm ready for criticisim for asking this, but I certainly would rather ask anytime i'm not absolutly sure about a subject so here we go.
I need to build a Slack Tube in the field to measure the pressure drop accross a few aftercoolers.
My plan is to use some 1/4"clear plastic hose, dyed fluid with a specific gravity of .833 =/-.
Now the real question is as follows; (example) If the fluid is depressed 25" on one side and raised 25"on the other side, is this 25 or 50 inches of water diferential?
Thanks in advance for any clarification that can be offered.
Pathfinder Tags: Slack Tube Help
Good Answers: 53
Re: Help with a Slack Tube PLEASE
08/02/2009 8:57 AM
Tim in Mexico
Its 50 Inches of ref liquid you are using.
Regards.
Re: How to Build a Slack Tube
08/02/2009 11:10 PM
Rakesh is correct, this site explains it clearly.
08/02/2009 11:46 PM
1/4" will give you problems with air bubbles, use 1/2".
And yes, the above replies are correct that the differential is the total of the two.
Good Answers: 16
08/03/2009 4:15 AM
Thanks for the clarification guys.... I thought that was correct, however the differental was at least twice normal prompting me to second guess a little.
Again, Thanks for the reply.
Good Answers: 19
08/03/2009 8:29 AM
Drop across (across) an aftercooler (diesel engine I suppose) will be in 'water column' pressure units, but manifold pressure (turbo boost) will be in mercury pressure units. So I take you literally meaning "across an aftercooler" and not what some books suggest as 'manifold pressure' which is also measured with a slack tube. Not sure why you are using low SG fluid, because this will affect your reading, but, bless you anyway !!! The SG looks like a hydrocarbon (diesel fuel?) .... careful with fire if so. If you use diesel, and it blows out onto a hot turbo, it may ignite.
You need to build a 3 (or 5 ) way manifold if you want to energised the slack tube while there is pressure already present or you'll blow the liquid out. i.e. 2 legs in / out of your slack tube across the AC, then a valve 'shunt' between the two legs, open before you start up the AC, then you close it while running and Delta P is applied on both sides of the tube at the same time so the liquid does not blow out of one side.
Cheers
Anonymous Poster (1); muzza (1); PetroPower (1); rakesh_semwal (1); Tim in Mexico (1)
