Previous in Forum: LP Rotor Disk Assembly   Next in Forum: What Does Steam Cost?
ATEX Certified Solenoid Switch
08/02/2009 10:02 PM
Hi,
I am looking for an ATEX certified Pressure switch that could activate a ATEX certified 2 way valve Solenoid valve. The whole idea is the ATEX certfied 2 way Solenoid valve would be activated by the Atex certified Pressure switch when the pressure in the system reaches about 1000 Psi. The Solenoid would be 24V.
Could someone please recommend
1) An Atex Certified Pressure Switch
2) An Atex certified 2 way Solenoid Valve
Thank you.
Re: ATEX certified Solenoid switch
08/03/2009 3:46 AM
What is the hazardous area zone in this instance?
08/03/2009 12:42 PM
Zone2, offshore location
Re: ATEX Certified Solenoid Switch
08/04/2009 2:51 AM
we use sirco atex pressure switches here in the uk or if its a SIL rated safety circuit, we would use a rosemount pressture tansmitter, P&F sil rated trip amp and guardmaster safety relay for your SIL1 or SIL 2 safety circuit all atex certified
Raise to the challange and do it safely
Good Answers: 68
08/04/2009 4:29 AM
Hello vanuta,
Hope you enjoy your CR$ time! The people here are very knowledgeable and helpful, just ask and an answer will be given. But you should give as much detail as possible please.
As you know this subject of Pressure Switches and Solenoid valves is a 'mine field'. These items vary in shape and size.
Having said that I have enclosed below the first two address' you see are the search address'. Read them and you will see I tried to search for the pressure switch and solenoid valves together. Can you look either at the searches or, at the few sites I copied from the searches which are further down the page. Please tell me if any of these are what you want, OK?
It sounds as if you know what you want to do and why you need these 1000 psi pressure switches, but keep in touch and let me know how you get on please. I do not know the application you want these for. So please view these and other sites. There is several sites actually connected to our sponsor on this site. If you search with your pressure switch etc you will get back a whole lot of site and factories which make these items. http://www.google.com/search?hl=en&client=safari&rls=en-gb&ei=8Op3Sor9I-TMjAffw-WoBg&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=atex+certified+pressure+switch+to+operate+atex+2+way+solenoid+valve&spell=1
http://www.google.com/search?hl=en&client=safari&rls=en-gb&ei=zOt3SuKaHN3LjAejpOGnBg&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=atex+certified+pressure+switch+to+1000+psi+to+operate+atex+2+way+solinoid+valve&spell=1
Design, manufacture & supply electrical equipment for "Ex" areas
Search Results CR4 - Thread: ATEX Certified Solenoid Switch 3 posts - 1 author - Last post: yesterday The whole idea is the ATEX certfied 2 way Solenoid valve would be ... switch when the pressure in the system reaches about 1000 Psi. ... cr4.globalspec.com/thread/.../ATEX-Certified-Solenoid-Switch?from...
- Similar -
Hydraulic solenoid valve - control valve | solenoid valves ... exclusive wet solenoids. Flow up to 1000 l/min. Pressure up to 350 bar. Special execution: ... Two Way Spool Valves are available in Normally Closed and Normally Open types. Two Position, Three Way Spool Valves .... ∙ATEX, FM, CSA, IEC and GOST certified. ... unload with a signal from the integral pressure switch ... www.directindustry.com/.../hydraulic-solenoid-valve-70800.html
- Cached - Similar -
Lobe pump - centrifugal pump | pressure gauge | solenoid valve ... ATEX versions compliant to 94/9/EC possible. Typical Applications For oil-free compression of gases .... Adjustable Discharge Pressure to 1000 psi (70 Bar) ... www.directindustry.com/industrial.../lobe-pump-76612.html
More results from www.directindustry.com » [PDF] The DAPC Choke Manifold File Format: PDF/Adobe Acrobat - View as HTML pump and switch to the auxiliary choke to maintain constant bottomhole pressure. .... Pressure Rating: 5000 psi (345 bar). • API 6A, DNV, ATEX-Certified. • Class 1/Div 2/Zone 2. • Spec'd for H ... Accumulator Size: Closes 2 Chokes/Valves If Pump Fails ... Pressure sensors. • Valve limit switches. • Solenoid valves ... www.atbalance.com/PDFs/AtBalance_DAPC_Manifold.pdf
- Similar -
[PDF] CNR-2LM-6MN 11012000 ATEX Rev.PMT File Format: PDF/Adobe Acrobat CNR-2LM-6MN Version 11012000 ATEX Rev. YZ Systems, 3101 Pollok Dr., .... 2. -SIG . 1IG. (1/4" FNPT). RELIEF VALVE. ROB VALVE. 500. 1000. 1500 psi ... The balance valve automatically senses pipeline pressure and .... supply (80 - 100 psi). The necessary regulator, solenoid valve, ... 2. 6*. Mode Switch. E1-0002 ... www.yzsystems.com/Files/.../cnr_2lm_6mn_11012000atex.r.pdf
- Similar -
[PDF] GSOV25 HT File Format: PDF/Adobe Acrobat - View as HTML The GSOV25 HT fuel isolation valve provides shutdown on a gas turbine by rapidly .... Certified to Pressure Equipment Directive 97/23/EC of 29 May 1997 on the approximation of the laws ... ATEX 6035X; Zone 2, Category 3, Group II G, Ex nA II T3 ... The three-way solenoid connects P1 pressure to the control land of ... www.woodward.com/pdf/ic/03286.pdf
- Similar -
Register to Reply 4 comments
Anonymous Poster (1); babybear (1); jeffweeden (1); PWSlack (1)
