Previous in Forum: Effective value of Fundamental and THD   Next in Forum: Fan Motor
Testing Motor Protection Circuit Breaker
08/02/2009 10:52 PM
I have a current source of 5V 1000A AC. I am unable to inject more than 100A for a 30A rating motor protection cuircuit breaker type GV2 series of schineider. Could it be due to high resistance of close circuit contacts of the motor protection circuit breaker? I collected the data sheet from the manufacturer and it does not contain the contact resistances.
If anyone has the data kindly advise me. This would help me to design a suitable test kit.
pscraja
Re: testing motor protection circuit breaker
08/02/2009 11:02 PM
It doesn't take much resistance to limit the current to 100 amps with only 5 volts. It could be anything and every thing in the circuit.
08/03/2009 9:40 PM
Thank you for your reply. Will you please be more specific. If you want any more data I can give. Your answer is evasive "it could be anything and everything in the circuit" means nothing. Be very specific if I have to check any specific aspect.
pscraja
Good Answers: 244
08/03/2009 10:02 PM
First try the injection set with directly shorting the terminals and see you can increase the current towards the high ampere rating (1000 A) of the set – do it carefully so that the high ampere current stays only for short time. This test tells you that the injection set is working or not.
If the injection set works, then make sure you connected the set's terminal to the relay properly with sufficient torque.
Then blame the relay.
- MS
Re: Testing Motor Protection Circuit Breaker
08/04/2009 5:19 PM
pscraja
Realize that with only 0.10 ohms the limit of the amps is I = E/R = 5/0.1= 50 amps. With a resistance of 0.01 ohms the max amperage is 500 amps. That's why I said it could be anything. Since the unit is only putting out 500 amps the unit resistance is only 0.05 ohms. That will be hard to eliminate.
Register to Reply 4 comments
msamad (1); pscraja (1); wareagle (2)
You might be interested in: Circuit Breakers, Circuit Protection Devices
