Previous in Forum: What Gauge Wire Do I Need?   Next in Forum: Capacitance Calculations
16 comments
Good Answers: 101
12V ~3000W Power Supply
08/03/2009 8:07 PM
I am currently attempting to source a high amperage power supply. This power supply must be capable of putting out a minimum of 211A @ 12V. I need to test some rather Interesting pump/motor groups operating on a 12V Mobile supply. The testing needs to be in the shop. The biggest DC power supply we have currently is capable of putting out 40A continuous, and 200A for a 5 second duration. I need to supply these with 211A continuous (according to the motor nameplate).
I have searched the net, and I keep coming to the fact that every power supply manufacturer says they can build it custom, but have nothing as a standard item. (maybe my web searching skills are sub-par?).
In these economic times, money for new equipment is not easy to come by, so ordering an expensive custom power supply is out.
One thought I have (if I can't find an actual shop DC high amperage 12V P.S.) is to set up a bank of 12V auto batteries, and just use the batteries for short duration tests, and keep them hooked up to the charger. I would rather not have to deal with a bunch of batteries if I don't have to.
Another thought I have is to possibly cannibalize a few of our (ridiculously numerous) out of commission welders to attempt to build some ugly monster supply. (this seems like a bad idea to me).
Anyone happen to know of an "off the shelf" 12V ~250A power supply? Or have any other cost effective Ideas I can use to test these units?
Pathfinder Tags: DC power supply 12V
Re: 12V ~3000W Power Supply.
08/03/2009 8:11 PM
You do not say how long the test runs. What about several Sears Die Hards in parallel.
08/03/2009 10:19 PM
It is not easy to get a 211A @12 power supply. The only thing that you can do is to construct yourself a 12 Vdc power supply. It can be easily done by using a 3500VA step down transformer with some high ampere rectifier and some capacitor for filtering network.
The step down transformer should be 110V or 220V/12V/3500VA. It depend if you have 110V for the primary side or 220V for the primary side. Add some MCB or MCCB for the safety protection against short circuited.
Good Answers: 53
08/03/2009 10:56 PM
Since your post don't indicate any requirements about the variability of voltage and current. In that case you can get a transformer with desired current and voltage ratings, and connect with bridge rectifier and big capacitor bank.
Regards.
08/04/2009 12:15 AM
When ever I need high current at a low voltage the constant voltage output on my welder works just fine for me.
Most MIG welders have reasonable regulation and with out much if any work they can be set up to do 12 -15 volts at several hundred amps. Just use one as a massive battery charger with one or two High capacity marine or deep cycle batteries as the smoothing filters.
Its as cheap as your going to get and still work well!
08/04/2009 2:11 AM
You must talk with the people of Dynapower. They have rectifiers power supply bigger than your needs and also they have switching power supply.
Doug Delaney
Dynapower Corporation
(802)652-1362
or
Michelle Trudell
Executive & Sales Assistant
DYNAPOWER/RAPID POWER CORPORATION
(802) 652-1315
Or you can check their web page at dynapower.com
I hope this helps
Jaime
08/04/2009 2:31 AM
APDC power supply sells new and refurbished power supply.
You can check this address
http://www.apdcpowersupply.com/products/index.php?controller=category&path=24
They have a unit with output of 12 Volts, 300 amp, with input 240 volts 3 phase power supply
Jaime
08/04/2009 3:16 AM
What about a simple rack of lead-acid batteries in parallel?
Good Answers: 266
08/04/2009 10:50 AM
How about an industrial battery charger. Some of those can have an output up to 400 amps. One that could charge an 12 volt industrial battery may come close. You may have to do some circuitry modifications. Visit a used equipment dealer of forklifts.
Good Answers: 101
08/04/2009 11:52 AM
Thank you all for the valued comments.
I think we are going to run the tests in a series of steps, which will eliminate the need to apply any power to the electric motors. But if by chance we do need to run a full system test, I'll just use a battery bank.
Thanks again!
08/05/2009 1:23 AM
If you choose to use battery bank for your test, then use adequate capacity battery. 200 Ah battery WILL NOT deliver 200 A for 1 hr. & you cannot adjust the voltage applied to the motor/load.
Thanks and regards
Ashok Toshniwal, Bangalore, India
Good Answers: 123
08/05/2009 9:46 AM
The welders that you currently have should be usable if they have a 12 volt or close output. There are sealed lead acid batteries used in UPS units that could be grouped together to reach your amp load. BUT, most of these units are small, and would require so many batteries, that it would be impractical. There are group 31 batteries that are designed for deep cycle use. Two of these should get you to the capacity you need. The other choice is n 8D. These are huge, and weigh over 130 pounds. I think the idea of the welder connected to a group 31 battery would give you good performance.
One other option would be to use 2 125-150 amp power supplies connected to a single battery, running to your device. Good luck.
Bob
08/05/2009 2:08 PM
A group of car battery is your best bet and probably much cheaper then a power supply.
Pineapple
08/05/2009 6:50 PM
Advanced Battery Supply co of china offers 3.2V cells at 100 up to 1000 Amps/ cell. They also have 10 Amp cells as well check out www.splendidbattery.com And NO I do not have any stock nor am I associated with this company except that I did purchase some Li Poly batteries from them a year ago ) thus 4 cells in series would give you 12.8V@ 100 Amps or 1280 Watts . The batteries do cost about 150 dollars each. Plus you will need to purchase the proper charger. LiFe batteries are more expensive then LIPoly batteries, but are safer to use. HLG
Good Answers: 12
08/08/2009 2:54 AM
Here is crude but very cost effective method. Take two metal plates and one small plastic container. keep two metal plates few inches away and connect firmly to the power supply. Now pour some water in to the plastic container and switch on the power supply under test. Now start brain solution or salt to the water watching current; go adding salt to increase current; if still current is less then you need large metal plate area or bring plates more closer. hope you got it by now!
Subramanyam
Good Answers: 101
08/10/2009 11:37 AM
HaHa.. Good one, But I don't think HHO will solve this problem, let alone any others!
We have Decided not to spin the 12V high current motors. We are going to leak/function test the manifolds on the test bench, and leak test the reservoir.
Good Answers: 12
08/11/2009 12:15 AM
Long ago I had to conduct load test a 3Ph Diesel generator. So I used 200 ltr drum salt water and three iron rods to load test successfully. I am working in large VRLA manufacturing plant. We use many types of discharges/ load banks (voltage rating 0~400VDC and currents 0~10,000 Amps)
Subramanyam
Register to Reply 16 comments
ashoktoshniwal (1); bob c (1); Jaime (2); kvsubramanyam (2); livagain1 (1); ozzb (1); Pineapple (1); PWSlack (1); rakesh_semwal (1); RVZ717 (2); Simon Wan (1); tcmtech (1); wareagle (1)
