Hallo everyone,
this is my first post since I have just subscribed.
I have the following problem:
IEC 61892-4 says that
"The typical rated voltage (U) for control and instrumentation cables considered in this
standard is 250 V.
In some instances for conductor sizes 1 mm2 and larger, or when circuits are to be supplied
from a low impedance source, 0,6/1 kV rated cables shall be used as control or
instrumentation cables"
I would like to understand which are the aforementioned instances.
Moreover, I usually use 250V rated cables for AI/AO/DI and 0.6/1kV ones for DOs (solenoids). Is this a good engineering practice or is there a better way to proceed?
Please consider there are 24VDC supplied circuits or 4-20mA loops.
Thanks in advance for your help.
Byez
