Previous in Forum: Cable Voltage Grade Selection   Next in Forum: Blogs about the Coating Inspection Industry
Tank Calculations
08/06/2009 11:44 AM
how to calculate the range of a DP Tx for closed tank
Re: Tank Calculations
08/07/2009 1:14 AM
Ref SHELL DEP 32.31.00.32 Appendix 01, they have provided detailed Caln
Regards
Jose
08/07/2009 4:01 AM
Copyrighted publication - make sure you have permission to use it first!
08/07/2009 3:21 AM
With a tape measure, and in the knowledge of the density of the fluid.
08/08/2009 7:34 AM
Density x gravity x height of the liquid You will need to connect the low pressure side of the tx to the top of the tank for a dry leg setup.
Bear in mind that you will have to compensate for any distance the DP TX is above or below the 0 point of the tank level.
Register to Reply 4 comments
Anonymous Poster (2); josej (1); PWSlack (1)
